Forums >> Revit Building >> Technical Support >> Rpc 3.5D Walking
Hello! I have a Rpc file and its a 3.5D object and it is Walking(MOving)....but dont know If it works on Revit and How to bring it into the project!
I tried to do Load Family-----bue doesnt works--have an error---data in your rpc file need to be manually upgrated!
thanks for your help
Post edited on 2006-05-18 20:25:47
Is your RPC from Archvision? If so, they have a compatability matrix at:
http://www.archvision.com/GetCompatibilityMatrix.cfm?ViewPlatform=8
Assuming compatability, you need to make or modify an "entourage" family which will hold the RPC definition. It is best to start with one of the standard Revit entourage people families and modify by adding a new type that will reference you new RPC file.
It is also important that you place the RPC file where Revit can find it. The default location is the long winded path of:
C:Documents and SettingsAll UsersApplication DataAutodeskRevit Building 9RenderingRPCPeople
I would not place it there, but creat a new standard location for yuor RPC files preferably on a server. In Revit's 'Settings>Options>Rendering[tab]' set a path to the new RPC folder location.
Then in your entourage family, make sure that the file properties of the RPC are set to the new RPC folder location for each entourage type. If set correctly, you will see the RPC preview in the family.
HTH
it works , very thanks for your help,but I have one question my file its from archvision and there the say that this rpc its moving....so how can i put it moving ? i have done a render but its not moving, or its just moves in a walkthrough?! how can i chose the way to rpc Walk ?
In archvision the compatability is YES - will only render static
Post edited on 2006-05-19 15:27:09
It will not move in Revit, it will only be the still static image.
Tom
Rpc Creator made Rpc can't load |
Wed, Oct 24, 2012 at 5:12:33 PM
RPC PRoblems |
Thu, Nov 17, 2011 at 7:48:36 PM
ArchVision RPC Component not showing in Views only in Renders. |
Fri, Sep 4, 2009 at 9:13:29 AM
2009 RPC files |
Thu, Sep 9, 2010 at 2:47:13 PM
RPC Files |
Tue, Apr 28, 2009 at 5:45:41 AM
Members: | 2104495 | Objects: | 23178 | Forum Posts: | 152299 | Job Listings: | 3 |
