48 Users Online (47 Members):
Forums >> Revit Building >> Technical Support >> Create New Family Type for Drop Down Menu Family Parameter?
0 Posts No Rating |
Hello,
I've created custom bathroom casework. It has a drop down to change configurations, for example, from 1 door, to drawers, or openshelves.
I have created a drop down menu in a family type parameter. The issue is that everything listed in 'casework' is in the drop down. I just want the 3 options (door, drawer, shelves), but it's taking everything, ie, benchtops etc.
Is there a way to create a new family type?
I have tried object styles with no luck, as the family type parameter doesnt select the subcategories for the dropdown menu.
Thanks in advance.
Most families that have a lot of options use a type catalog. That means that every combination is a new type in the catalog.
0 Posts No Rating |
Thanks for your reply.
I suppose that would work.... but I was hoping to have a different set up with a drop down menu to nominate which upgrades the client wants in a particular type.
Ie. Cabinet type 1: Standard Benchtop..... user can upgrade 2 of the doors - to drawers, or shelving.
Cabinet Type 2: has a Fascia.... same upgrades in tickboxes apply.
Cabinet Type 3: has a Tiled Kicker..... so on and so forth.
If I set them up in individual types, it would be Benchtop with Doors, Benchtop with Drawers, Benchtop with Shelves, Fascia with Doors, Fascia with Drawers, Fascia with Shelves, etc etc, which is a lot of configurations depending on how many upgrades will be available etc. Each type is then open to setting up errors and user errors, if I have just 4 types with tickbox options this mitigates a lot of this potential for error.
Thanks again.
Family Type driven length parameter help |
Thu, May 1, 2014 at 3:08:42 PM
adding parameters to a family with a type catalog |
Thu, Feb 19, 2009 at 11:10:20 AM
Drop down list for room tag , and add the parameter to project parameters |
Thu, Jan 6, 2011 at 2:59:01 AM
<Family Type> parameter can't be controlled by formula. What else can we do? [ 1 2 ] |
Tue, Aug 27, 2013 at 3:53:53 AM
29
excluding a type in the family type parameter |
Thu, Mar 20, 2008 at 3:38:32 AM
Members: | 2022252 | Objects: | 22975 | Forum Posts: | 152202 | Job Listings: | 3 |
