56 Users Online (55 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> How do you share a parameter between several different sheets?
Thu, Nov 10, 2016 at 11:36:01 AM | How do you share a parameter between several different sheets?
cboersen
Revit 2017
I thought if I created a shared parameter and then linked it to a label in several different sheets and made a project parameter from the shared parameter that they would all be linked.  however, they all change independently.  How do I make a parameter than can be shared with several different sheets and when it is changed in one location it will update in all locations
Thu, Nov 10, 2016 at 1:07:54 PM | How do you share a parameter between several different sheets?
cboersen
There are parameters in a Revit sheet that do this like "project number".  Is it just that you cannot add your own and you have to stick with the list that comes with a Revit sheet and that is it?
Thu, Nov 10, 2016 at 1:48:51 PM | How do you share a parameter between several different sheets?
You can assign parmaters to sheets that are type - not instance.
Thu, Nov 10, 2016 at 2:34:11 PM | How do you share a parameter between several different sheets?
cboersen
The only place I see an option for type vs instance is when creating a project parameter and I do not see Title Sheets in the category list for either.  Also, there is not a type or instance option for creating a shared parameter and there is not that option when adding a parameter to a label within a title block.
Where do I make that instances vs type decision that makes this work?  Or is it not Title Sheet category with project parameter that I am looking for?
Thu, Nov 10, 2016 at 2:49:26 PM | How do you share a parameter between several different sheets?
cboersen
I did find that you can an a parameter with a instance vs type option with family types in a title block.  I cannot figure out how to relate that to a label on the title block.  I'm still missing something.
Thu, Nov 10, 2016 at 3:15:54 PM | How do you share a parameter between several different sheets?
There is no title sheet definition in Revit - only sheets.   Title sheets are a sheet.
If you want this parameter to show up in the titleblock rather than the sheet properties of the project, you will have to add it to the sheet family instead.
Filtering placeholder sheets by discipline in a sheet list
Thu, Jun 23, 2011 at 12:27:04 PM
Titleblock Parameter is now Instance instead of Type
Tue, Feb 17, 2015 at 3:31:00 PM
Add Family name to a shared parameter
Tue, Jun 23, 2015 at 8:50:48 AM
Parameters that propagate across sheets?
Fri, Dec 6, 2013 at 5:02:39 PM
Number of sheets in a set
Thu, Oct 11, 2012 at 6:54:16 AM
Page generation time: 1.9344
