72 Users Online (71 Members):
Forums >> Revit Building >> Technical Support >> Scale Familiys?
![4.5 Stars: 2 Votes](/images/stars_4.5.gif) |
So,
Since I am working on my revit project I was alwaways wondering if it is somehow possible to scale an object and I saw these amazing statues but unfortunately they are way to small. However the creator of the familiy has written in the describtion of the familiy that it would be easy to scale it?
Quote from describition "These are made at or just below 12inches high, but can be scaled in Revit to any size you want,..."
http://www.revitcity.com/downloads.php?action=view&object_id=12592
Can someone please help me and tell me how to scale?
Thanks
![3.5 Stars: 4 Votes](/images/stars_3.5.gif) |
this is a dwg file imported into a family , so to scale you will have to go insiide the family and you will find the whole sculpture as 1 object and you will find the scale order is available
Hi, thanks for the answer! I'm super new into revit So hoe do I get into a family?
if you are new try to always use the revit help itselp mostly its very usefull if you know to to search in it effectively.
that 's a link from Revit Help :
http://help.autodesk.com/view/RVT/2016/ENU/?guid=GUID-A46EBD5A-FA83-4D49-94A3-E29C7357A496
hope this helps .
Scale bar on sheet onto to display at certain scale |
Wed, May 22, 2013 at 12:15:22 AM
scale image |
Fri, May 13, 2016 at 1:11:44 PM
Scale Bar Link To Titlesheet Scale. |
Thu, May 23, 2013 at 6:36:16 PM
scale check |
Tue, Oct 23, 2012 at 5:05:08 AM
changing the scale of my room and area tags with the scale of my area plan. |
Fri, Oct 22, 2010 at 10:38:38 AM
Members: | 2017201 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
