96 Users Online (95 Members):
Forums >> Revit Building >> Technical Support >> Floor Tag elevation
0 Posts No Rating |
Hi All. I am trying to set up a floor tag that shows the elevation from the survey point as well as the floor type. i can use a label to show the elevation from the project base point, but there is no label for the survey point. This may not be best practice but its what is need to show in this case. Does any know how i can achive this. Can i do this by seting up a shared parameter. thanks
Simply edit your elevation tag to create a new one that references the survey but it will not be a combination tag. You will have to use a seperate floor tag.
Floor tag - elevation spot |
Thu, Apr 27, 2017 at 7:20:09 AM
BOP Tag for 2nd floor and above |
Wed, May 20, 2009 at 10:03:04 AM
Issues with Pipe elevation tagging |
Mon, Aug 24, 2015 at 8:23:31 AM
Interior elevation tag not cropping to floor/ceiling/walls |
Wed, Aug 18, 2010 at 9:31:49 AM
Invert Elevation Tag |
Wed, Jul 23, 2008 at 11:24:53 AM
Members: | 2017174 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
