65 Users Online (63 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Call out View
Sun, Nov 6, 2016 at 11:32:20 AM | Call out View
Westview
2.5 Stars: 2 Votes
Hi
I created a elevation view in the floor plan and when I create a callout view the elevation tag wont show in the callout view.
Also in the callout view there is no option to create a elevation view. How can I see the elevation tag in the callout view?
Thanks Ed Knight
Sun, Nov 6, 2016 at 10:18:21 PM | Call out View
Elnazer2
4 Stars: 5 Votes
copy all the 2d items you want to copy ( In elevation ) and paste aligned to the same view ( In Callout )- but most likely you will have to adjust the Tags And dimension sizes to fit in the new scale of the callout.
Mon, Nov 7, 2016 at 9:49:31 AM | Call out View
Westview
2.5 Stars: 2 Votes
Thanks for the reply.
Its the elevation tag, that is not a 2D item, that won't show up in the call out view.
Mon, Nov 7, 2016 at 10:16:14 AM | Call out View
First, are the elevation callouts on in VG settings?
If so, then change your view scale to something larger then your current setting and the tags should show.   Now click on one of them and look at the properties ..."hides in views coarse than"....
Mon, Nov 7, 2016 at 3:05:35 PM | Call out View
Westview
2.5 Stars: 2 Votes
Thanks so much I had the level set to Course.
Changing options on call out views so able to see on all floors
Thu, Oct 29, 2009 at 6:33:52 AM
crop call out
Sat, Mar 3, 2012 at 1:06:48 AM
Call outs in Revit
Wed, Jun 11, 2008 at 8:39:24 AM
Call outs withing call outs
Sun, May 10, 2009 at 3:35:43 PM
Can I call out from a legend view
Thu, Oct 15, 2015 at 10:57:53 AM
Page generation time: 3.2449
