42 Users Online (40 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Filled Region / Masking Region Transparency override
Tue, Nov 1, 2016 at 8:22:23 AM | Filled Region / Masking Region Transparency override
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Has anyone had a problem with getting a transparency for Filled or Masking Regions in Revit 2017?  I have downloaded all of the updated, tried turning off hardware exceleration and nothing.  For a maskign region I have to turn the transparency up to 100% to get it to work, for a filled region it will change colors like it is going transparent put still can't see through it.  It does however look right when I am in the plan but as soon as I switch to the sheet it isn't transparent anymore.  Any thoughts?
Thu, Nov 3, 2016 at 2:15:47 PM | Filled Region / Masking Region Transparency override
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Bump.. Not working with model elements either.
Fri, Nov 4, 2016 at 10:43:58 AM | Filled Region / Masking Region Transparency override
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Attached 2 images, one is an image in the plan view and the other is the image on the sheet.  You can see the transparency is gone on the sheet! Even if I click in the viewport on the sheet it doesn't appear.  Any thoughts?
Fri, Nov 4, 2016 at 11:45:00 AM | Filled Region / Masking Region Transparency override
3.5 Stars: 395 Votes
Teafoe, Your on subscription - right?   Send the file to Autodesk
Fri, Nov 4, 2016 at 11:55:09 AM | Filled Region / Masking Region Transparency override
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I am and I just did but I just figured out what the problem is.  We do a custom crop region on our site plans, our architects like to see random jogs and not just a square box.  Well for some reason in 2017 when you do that it removes the transparencys overrides, as soon as I reset the crop box everything goes back to normal.  A very weird bug!  I will let Autodesk know my findings.
Masking Region Fill Region Problem
Mon, Mar 10, 2008 at 11:06:24 AM
Masking region transparency
Mon, Jan 20, 2014 at 1:02:34 PM
Remove Model Filled Region @ Fixtures
Wed, Aug 15, 2012 at 4:19:33 PM
Filled Region Transparency
Fri, Apr 16, 2004 at 2:32:31 PM
Line tool shortcut when in a masking/filled region..
Mon, Feb 14, 2011 at 4:00:46 AM
Page generation time: 0.9995
