101 Users Online (100 Members):
Forums >> Revit Building >> Technical Support >> View Range Problems
0 Posts No Rating |
Im having trouble configuring my view range. No mater what I do I can not get elements from a lower level to go aways.
For example.
Level 1 - Main Floor is showing the foundation below it. even with a floor in place.
The view ranges is set as follows:
Top: Associated Level, Offset 8'
Cut Plane: 4'
Bottom: Associated Level, 0'
View Depth: Associated Level, 0'
it also seems to be messing with my electrical layout as well
![pijpiwo Avatar](user_avatar/187179.jpg)
![5 Stars: 25 Votes](/images/stars_5.gif) |
In the view properties, make sure Underlay is set to None.
0 Posts No Rating |
holly..... $^*&@.... that was easy!
thank you very much. Im going to go beat my head on a wall now
View range problems with framing plans |
Tue, Feb 23, 2010 at 1:48:16 PM
View Range problems- seeing wall detail |
Fri, Jun 6, 2008 at 8:56:57 AM
view range |
Fri, Sep 7, 2007 at 2:28:04 AM
View Range |
Tue, Aug 28, 2007 at 9:52:27 AM
View Range for Revit Link |
Thu, Nov 12, 2015 at 7:10:18 AM
Members: | 2017117 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
