Forums >> Revit Building >> Technical Support >> Floor pattern not visible in plan view
5 Posts No Rating |
Hello - hoping someone can help. I have created a new floor type and assaigned a material to it with a model surface pattern. It shows up in the 3D view, but not in the floor plan. I have checked VG overrides, worksets, view range and even tried painting it. Nothing worked. Anything I am missing? Thanks for any ideas!
More than 99% chance that you have done something to create this problem. Look again at your plan settings for cut plane and also at your VG settings. Is there a plan region? You might create a new plan of the same floor without any template from the plan dropdown. Don't copy your plan - make new. Cut a section and make sure something is not hiding like another floor or layer.
Something is strange in your views. In the 3D, I see what must be 2 different floors but they are both blue and I see a blue limit line in the larger area. What is what?
Any filter applied to the view, or overrride graphics by element?
5 Posts No Rating |
still no luck... made a new plan, checked for hidden objects in section. im at a loss. very odd b/c the floor outline shows up in plan, but not the surface pattern.
I had two different types of floors highlighted in blue in the image i sent.
5 Posts No Rating |
double checked and no filters or overrides
Can you delete everything but floors, purge and upload, so we can troubleshoot?
5 Posts No Rating |
trying to upload - but cannot get the file size down to 2Mb. Purged and deleted everything. any tips on uploading?
Can you upload to cloud and provide a link for us?
You need to purge 3 times to really get rid of everything. If you have gotten everything else out, include deleting groups from the family area, then the file size will be OK.
if you are using phasing check the phasing overrides
Floor Slab not visible in Plan! |
Tue, Nov 9, 2010 at 1:58:17 PM
roof not visible in enlarged plan view but visible in all other views 2017 |
Wed, Dec 13, 2017 at 1:19:40 PM
invisible object on floor plan |
Fri, Jul 30, 2010 at 8:07:11 PM
walls not visible on floor plan |
Thu, May 13, 2010 at 7:20:15 AM
Floor Plan View |
Sat, Mar 17, 2007 at 7:38:08 AM
