Forums >> Revit Building >> Technical Support >> Wall Opening
3 Posts No Rating |
Hi,
Have edited a window opening in a family and have made it to big.
How do i re edit the wall to fill the bit of the opening that i do not need.
TIA
3dShed
Resize the opening in the original family
Or u can select the opening u made and edit it. just hold the cursor near the wall and opening and hit TAB until it marks the opening
Is it possible to control the depth of a wall opening? I have one window that needs to be placed in a masonry opening on the outside but up against a stud wall on the interior. Not sure how to do this. Any help would be appreciated. Thanks.
2 Posts No Rating |
"Is it possible to control the depth of a wall opening? I have one window that needs to be placed in a masonry opening on the outside but up against a stud wall on the interior. Not sure how to do this. Any help would be appreciated. Thanks."
YOu need to build your window with an inset parameter. To do this, open the family, add a ref. plane in plan that will locate the exterior face of the frame. Then place a dim from the ext. face of the wall to this ref. plane, label it inset, then when you create your window frame align it with this ref. plane. Note you can either make this inset parameter an instance based parameter or type depending on how flexible you want to be.
Control the depth of a wall opening? |
Wed, Jan 19, 2011 at 2:09:24 PM
Wall Openings |
Mon, Mar 9, 2009 at 2:40:23 PM
Why does the wall opening cut only go up 2/3 the height of the wall? |
Sun, Feb 18, 2007 at 8:53:26 AM
Windows/opening/curtain system on inclined wall |
Tue, Apr 21, 2009 at 5:16:46 AM
Wall opening family in slanted wall |
Thu, Sep 6, 2012 at 2:50:58 PM
Members: | 2098622 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
