27 Users Online (26 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Dome roof
Tue, May 16, 2006 at 10:01:49 PM | Dome roof
Carver
I am having some trouble drawing a dome roof. The trouble is that it is a dome that is square in plan. Imagine a dome that tapers down to meet a the corners of a square structure. Does this sound impossible to model in Revit? Thanks a bucket.
Tue, May 16, 2006 at 10:21:42 PM | RE: Dome roof
Thread Post Kudo! #2
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Is this sort of what you're after?
Tue, May 16, 2006 at 10:43:02 PM | RE: Dome roof
Carver
Yes, Well very similar anyway. the top should be spherical. Like a dome but this would be close enough. Can you fillet the edges where the egdes meet aswell? Cheers
Wed, May 17, 2006 at 5:22:48 AM | RE: Dome roof
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You could easily sweep another void along the edges to smooth it off a bit, i was just keeping it simple and reducing the number of lines. Its created as a mass and consists of two sweep solids and two sweep voids. All very simple arcs. Let me know if you want the file.
Wed, May 17, 2006 at 10:15:16 AM | RE: Dome roof
arch00
Mr. Spot would it be possible if I get a copy of this file as well I would like to try and learn how to use this command. Just curious if you are running your version of Revit on a Mac platform, cause it looks very similiar to it. Thanks Gar
Wed, May 17, 2006 at 10:49:10 AM | RE: Dome roof
coreed
coreed Avatar
4 Stars: 16 Votes
i think he is using s program called Flyakite OSX which run on windows and simulates the mac here is a link http://osx.portraitofakite.com/
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, May 17, 2006 at 9:42:31 PM | RE: Dome roof
Carver
Mr Spot, Thanks, I tried this approach but I still wanted a spherical top. With some help from my teacher I have revolved a dome so the leading edge meets the very corner of where the walls meet. Then placed a void to cut the over hang from the outside face. From here I'll just attach the walls to the dome. It's a simple approach and it's not spot on but it might have to do. I'll attach a JPEG when I work out how.
Fri, Apr 2, 2010 at 12:05:02 PM | Dome roof
Uncluesteve
I have a dome structure we started to design.  I had to do the main layout in AutoCAD then create a mass object in Revit to start the beam layout.  Unfortunately Revit does not like to place objects out in space, especially when there are not parallel to a floor plan.
Fri, Apr 2, 2010 at 12:14:21 PM | Dome roof
For something like that, i would rotate the dome back to my xy plane - create what i had to, then roatate everything back.
Fri, Apr 2, 2010 at 12:23:36 PM | Dome roof
Uncluesteve
Tried that.  unfortunately Revit does not like to rotate beams and columns.  They tend to move all over the place.
Mon, Apr 5, 2010 at 7:26:43 AM | Dome roof
#11
Are you really using (structural) beams or just beam like objects?  Although structural elements can be a problem, components created in place will rotate just fine.
Mon, Apr 5, 2010 at 10:15:48 AM | Dome roof
#12
Uncluesteve
Creating  nearly 160 work planes so I can create a In-place object would nearly be imposable to do accurately.   I am trying to create a model that a structural engineer can use to correctly size the beams and connection plates.  See the DWF file for a better illustration.
Mon, Apr 5, 2010 at 1:50:28 PM | Dome roof
#13
I think your missing the power of Revit.  You need to do something like Mr. Spot did here: http://blog.cadway.com.au/
Wed, Jan 5, 2011 at 5:56:02 PM | Mr Spot
#14
halozero
Quoting Mr Spot from 2006-05-16 22:21:41
"Is this sort of what you're after? "
I NEED THAT DOME SQUARE ON REVIT, DO YOU HVE IT? I HAVE BEEN LOOKING FOR IT EVERYWHERE.
Mon, Jan 17, 2011 at 7:52:23 AM | Dome roof
#15
tuneslover
Ohkk..it you don't have any other way then you can do it in 'Revit Family' and import it in your project.
Dome Roof?
Mon, Oct 1, 2007 at 2:16:40 PM
Dome roof openings
Tue, Aug 16, 2005 at 3:37:25 AM
Dome Roof
Wed, Sep 27, 2006 at 12:32:47 AM
Create a half dome
Mon, Nov 11, 2019 at 5:37:43 PM
Dome Roof for Astronomy club
Tue, Jan 31, 2006 at 4:08:08 PM
Page generation time: 0.5017
