Forums >> Revit Building >> Technical Support >> LEVELS
I HAVE A GHOSTED IMAGE ON MY ELEVATONS THAT SAYS TEMP LEVEL 1. I DIN'T PLACE IT THRE AND I CAN'T SELECT IT TO DELETE IT. ANY HELP ON THIS WOULD BE GREAT.
THANKS
----------------------------------- PWD |
This is a bug and as far as i know the only way to remove the temp levels is to either copy the work into a new project or send the file to support...
admin
Yup, we were having this problem and that's the only answer I could get... call support.
Hiroshi Jacobs
The Catholic University of America |
Was this issue ever resolved? Just come across it...
Send to support, there is a way to select them using the select all instances... can't remember the exact process. I'm sure if you did a search on www.augi.com on temp levels you should find it...
Resolved... thanks
sorry i did not reply sooner, i thought i posted how to fix it on this site, but it may have been on augi. i can not remember.
i know i took me about 2 weeks to get my project file back from support so asked for directions how to fix it and that is what i posted somewhere. sorry i can not be more specific.
i have recently changed jobs and i do not use revit there, i still use it home for my own projects. i miss usoing it at work. powerdraft by micostation is miles behind revit. but i am talking to my new employer about the benifits and potetnal cost saving of revit. who knows wha tmy future holds.
Replacing levels with ref planes or deleting excess levels |
Thu, Apr 17, 2008 at 11:10:38 AM
Levels missing Revit 2012 [ 1 2 ] |
Mon, Sep 28, 2015 at 3:29:42 PM
19
Levels, Disappeared. [ 1 2 ] |
Sun, Sep 24, 2017 at 7:44:34 AM
16
Floor levels slightly offset |
Mon, Nov 5, 2012 at 10:23:47 AM
walls look different on different levels |
Thu, Mar 11, 2010 at 2:38:20 PM
Members: | 2100201 | Objects: | 23171 | Forum Posts: | 152293 | Job Listings: | 3 |
