66 Users Online (63 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> curtain walls aluminium corner profile
Tue, May 16, 2006 at 11:11:54 AM | curtain walls aluminium corner profile
elvis
hi all, someone knows how to creat a 45 degree aluminium corner profile for a curtain wall system? I also need more parameters to displace de mullions by a certain distance not only an offset in one direction. grtz E
Tue, May 16, 2006 at 5:25:55 PM | RE: curtain walls aluminium corner profile
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Corner mullions are a special creature and you can't use custom profiles to create them. You would need to use the trapezoidal mullion for a 45° corner. If you are using a curtain system (sounds like you are), you can select any individual grid. You'll see a pin appear, click this to unpin its position/settings. Now you can freely move it to the appropriate location. HTH.
Curtain walls
Mon, Nov 7, 2011 at 10:28:34 AM
Changing render colour of aluminium cladding
Thu, Mar 22, 2012 at 12:40:01 PM
corner join
Tue, Mar 14, 2006 at 3:52:39 AM
Commercial Aluminium windows
Mon, Oct 31, 2005 at 7:57:33 AM
Corner Mullions
Fri, Dec 6, 2013 at 11:05:59 AM
Page generation time: 1.6869
