94 Users Online (92 Members):
Forums >> Revit Building >> Technical Support >> Interior Elevations
29 Posts No Rating |
Hi all,
When we show interior eleavtions, we just show the entire wall with thick outline. How can I do that in Revit?
![Mr Spot Avatar](user_avatar/1073.jpg)
![4.5 Stars: 93 Votes](/images/stars_4.5.gif) |
Create an interior elevation, the extents should pick up the length of the wall, if not adjust the crop region as required.
To get the thick outline, in your view properties add an override for walls-->projection and make it a heavy linetype.
Then save this view as a view template and you then quickly apply its settings to your other interior elevations.
HTH.
Problem with Interior elevations |
Fri, Feb 13, 2015 at 1:51:29 PM
interior elevations |
Wed, Apr 11, 2007 at 9:43:04 AM
Interior Elevations Referencing Detail Numbers |
Sat, Oct 13, 2007 at 11:04:39 AM
Interior Elevations |
Mon, Jan 23, 2006 at 5:42:42 AM
rotating interior elevations |
Fri, Mar 17, 2017 at 6:52:25 AM
Members: | 2017035 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
