70 Users Online (69 Members):
Forums >> Revit Building >> Technical Support >> How do you make cantilevered Roofs?
1 Posts No Rating |
I was wondering how to make cantilevered roofs. Do you use the basic roof command or do you make a generic family
I just use the basic roof command and draw the roof to where the cantilever will go to.
Gar
One thing that you can do is put a wall in the location where it bears create your roof with that wall and then delete the wall. It works great.
You don't need walls to exist in order to insert a roof...
I know that you do not have to have walls to insert a roof. It makes it eaiser when trying to get the overhang to match with the rest of the building.
![dgcad Avatar](user_avatar/6183.jpg)
![3.5 Stars: 36 Votes](/images/stars_3.5.gif) |
You can draw a roof by footprint with or without the walls but there are some 'Must Kmow' behavours. Once you know these tendencies you'll be rock'n
Below are a couple great video CADCLIPs explaining the in's and out's of roof alignment and roof edges
right click and 'save target as' to download.
http://www.dgcad.com/downloads/CADCLIP-REV-VARYING-ROOF-PLATES.wmv
http://www.dgcad.com/downloads/CADCLIP-ROOF-EAVES-ALIGNMENT.wmv
* Also check out www.revitrocks.com or www.dgcad.com for more free CADCLIPs and tutorials
Cantilevered roof cable an brackets |
Fri, Oct 24, 2008 at 3:51:55 AM
Tapered cantilevered beam with openings |
Mon, Aug 14, 2006 at 5:06:16 AM
cantilevered steel balconies |
Fri, Aug 3, 2007 at 9:25:58 PM
question re: extending walls into roofs |
Tue, Feb 10, 2004 at 3:13:38 PM
joining roofs |
Mon, Jan 9, 2006 at 1:20:09 PM
Members: | 2016954 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
