66 Users Online (64 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Room seperation lines
Fri, May 12, 2006 at 3:50:21 PM | Room seperation lines
gdoorn
1 Stars: 1 Votes
i have a mezzanine in a small retail area. when i drop a room tag into this mezz, it recognizes the level below. when i draw room seperation lines, they are drawn at the lower level. what do i need to do to get an accurate area shown on my blow up plans, withough subdividing the main level? Thanks
Fri, May 12, 2006 at 5:19:36 PM | RE: Room seperation lines
Rookwood
Make certain that you have a 'MEZZANINE' Level. If not, go to any elevation view and create a new level called 'MEZZANINE LEVEL' and set the appropriate level height. Rename the level to 'Mezzanine' and agree to rename the plan view. Go to the 'Mezzanine Level' in the Project Browser Floor Plan. Create your floor to the specs desired. Use the room separation tool under 'Room and Area' Revit 9) and place this line at the edge of the mezzanine floor. You should then be able to tag your room.
Mon, Mar 8, 2010 at 5:01:06 PM
Rooms - editing room seperation lines
Fri, May 16, 2008 at 5:29:30 PM
Room seperation
Fri, Dec 11, 2009 at 3:31:55 PM
Mysterious Room Seperator
Fri, Feb 3, 2012 at 2:39:07 PM
Room seperation at center of wall?
Sun, Jan 7, 2018 at 1:38:24 PM
Page generation time: 2.5168
