83 Users Online (82 Members):
Forums >> Revit Building >> Technical Support >> Dimension Display in Inches
29 Posts No Rating |
How can I display my Dimensions smaller then 1'-0" in Inches...rather then 0'-5"
on the pull-down menu select
Settings ==> Annotations ==> Dinensions ==> Linear...
From the Type Properties Dialog Box that pops-up
Click the button to the right of Units Format under the Text section
From the Format Dialog Box that pops-up
put a check in the box next to Suppress 0 Feet
HTH
Can you do this for inches too? So dimensions will read 4'-1/2". Rather than the default: 4'-0 1/2" ?? Thanks, Lorne
Denver, CO
Revit Architecture |
DIMENSION SETTINGS |
Thu, Jun 12, 2008 at 12:54:38 PM
Dimension Inches w Replace text not working |
Thu, Feb 27, 2014 at 7:13:14 AM
Dimension Text [ 1 2 ] |
Tue, Jul 8, 2008 at 9:15:07 AM
18
tag display paramenter |
Mon, May 16, 2011 at 2:50:11 PM
Revit Reporting Parameter |
Tue, Aug 6, 2013 at 10:47:43 PM
Members: | 2056445 | Objects: | 23069 | Forum Posts: | 152325 | Job Listings: | 3 |
