71 Users Online (69 Members):
Forums >> Revit Structure >> Technical Support >> structure analys with Revit
12 Posts No Rating |
Hi
I have wroten a program with Excel to calculation of bending moment. Can I somehow transfer it to Revit to calculate a bending moment for exemple for a slab. Or can I directly write this program in Revit! is it possible that wirte formula in revit to calculation like this.
Many thanks for your help
![rkitect Avatar](user_avatar/4651.jpg)
![4 Stars: 29 Votes](/images/stars_4.gif) |
Yes, you can use formulas to calculate paramter values and you can use formulas in schedules. There are some tutorials on how to do that in the Help menu. I think the syntax will be a little different from that in Excel though, but should be able to do the same stuff.
Speaking of which, does anyone know of a reference to the various formula calculations available in Revit?
You fell victim to one of the classic blunders. The most famous is never get involved in a land war in asia, but only slightly less well known is this! Never go in against a Sicilian when death is on the line! |
![4.5 Stars: 25 Votes](/images/stars_4.5.gif) |
Your best bet for formula usage is to log-in to the subscription center, go to the AU2005 site and download the handout for class BD35-2 "Take Your Autodesk Revit Building Family to the Next Level" by Dave Conant and Steve Stafford. The handout contains all of the forumla syntax plus the use of conditional formulas.
Tom
[quote= rkitect - 2006-05-11 09:28:02]Yes, you can use formulas to calculate paramter values and you can use formulas in schedules. There are some tutorials on how to do that in the Help menu. I think the syntax will be a little different from that in Excel though, but should be able to do the same stuff.
Tom[/quote]
I search in www.au2005.com but couldn't find that handout. Is it possible for you that link the page?!
Thank you very much
![coreed Avatar](user_avatar/14568.jpg)
login to the subcription center. you will see the link on the right side of the screen
http://pointa.autodesk.com/local/enu/portal/signin.jsp
HTH
Metalic Structure in Revit Architecture |
Fri, Dec 3, 2010 at 1:10:10 PM
Modyfing columns in Revit Structure |
Thu, Nov 1, 2007 at 12:55:53 PM
Revit STRUCTURE |
Fri, Jun 17, 2005 at 2:45:21 PM
Hello All! Moving Revit Arch Drawing to Revit Structure Problems |
Thu, Feb 12, 2009 at 8:18:59 AM
Need HELP!! Geting a Navisworks file inn to Revit Structure |
Mon, Apr 8, 2013 at 8:02:00 AM
Members: | 2022271 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
