41 Users Online (40 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Wood Slats
Wed, May 10, 2006 at 1:27:50 PM | Wood Slats
arch00
How would I put a layer of wood slats below an existing drywall ceiling? Gar
Wed, May 10, 2006 at 1:36:37 PM | RE: Wood Slats
TomDorner
4.5 Stars: 25 Votes
Are you attempting to model them? How big of an area are we talking? A single room or an entire building? Is it for rendering purposes only? Do they need to show in section? Do you need to count them? There are a number of different methods, but helps to know more about the situation. Tom
Wed, May 10, 2006 at 1:52:24 PM | RE: Wood Slats
arch00
About 4-500 sf, I would like to make the numbers accurate but if it is going to slow the model down alot then that might not be neccessary. Gar
Wed, May 10, 2006 at 1:59:17 PM | RE: Wood Slats
TomDorner
4.5 Stars: 25 Votes
I would tend to use a compound ceiling with a layer that is as thick as the slats that I place directly below the existing GWB ceiling. Give the ceiling a surface pattern to represent the slats in RCP and if rendering a Accurender material. If you have to show the slats cut in a large scale section, I would use a repeating detail component to represent them. You could also develop a slat family that you bring in and array as required, but that adds overhead and may not buy you that much more that the above method. HTH Tom
Curtain wall with Wood Slats
Wed, Apr 13, 2011 at 10:32:53 PM
Rainscreen/wood/vertical...how to?
Tue, Mar 11, 2014 at 11:36:09 PM
Generic Model Materials
Wed, May 18, 2005 at 4:19:44 PM
Wood floor way too shiny.
Tue, Dec 14, 2010 at 7:32:39 AM
Wood Siding
Fri, Nov 22, 2019 at 3:17:58 PM
Page generation time: 0.2467
