55 Users Online (54 Members):
Forums >> Revit Building >> Technical Support >> Viewport titles
![5 Stars: 2 Votes](/images/stars_5.gif) |
When I place details on my detail sheets and enter the detail title, Revit stacks the title automatically is there a way to stop Revit from doing that? I have created custom titles and I sill have the issue. I figure that I am not the only one that has had this issue with longer detail names.
![4.5 Stars: 25 Votes](/images/stars_4.5.gif) |
You need to make a new view title family that has the field for title expanded so the title does not wrap as it is doing. I've attached one of mine you can reverse engineer or modify.
Once you have the view title family to your liking, load it into your project or template.
You then need to either modify an existing viewport title to use this new family, or duplicate and create a new viewport title type that uses the new view title family. Go to the type properties of the viewport title and in the 'Graphics" "Title" choose you new view title family as the one to use for this viewport title type.
Be sure to set the viewport title type of your view placed on the sheet to the new viewport title type (available in the drop-down box list)
Tom
Post edited on 2006-05-09 16:28:53
Post edited on 2006-05-09 16:30:15
Thank you that worked, I guess that I did not make the label box large enough.
Viewport Titles |
Thu, Jun 30, 2011 at 8:19:48 AM
Multiple Viewport Titles in same sheet |
Wed, Jul 30, 2008 at 7:16:18 PM
Purge unused Viewport Titles |
Thu, Aug 30, 2018 at 10:41:49 AM
11
Viewport titles moving |
Mon, Nov 10, 2008 at 10:16:48 AM
Viewport titles - how to modify them? |
Sat, Feb 2, 2008 at 9:40:37 PM
Members: | 2017168 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
