84 Users Online (83 Members):
Forums >> Community >> Newbies >> ELEVATOR
1 Posts No Rating |
How do I show the door opening of an elevator on 1st floor infront and on the 2nd floor at the rear?
if it is the same elevator, with a door at the front and rear
then you could could use a plan region to control the display of each door
HTH
2 Posts No Rating |
NEW PARAMETRIC ELEVATOR FROM REVIT CONTENT.COM IS VERY IMPRESSIVE, YOU CAN CREATE ANY CABIN FROM ROUNDED TO SQUARED SHAPES AND HAVE ALL THE ELEVATOR TYPES. THE ALL IN ONE FAMILY HAS A CATALOGUE FILE.....WHICH ALREADY HAS ALLOT OF OTIS PRE SET TYPES. BY FAR THE BEST FAMILY I HAVE SEEN.... ALL THE OTHE FAMILIES I HAVE PURCHASED ARE AMAZING www.revit-content.com
Elevators by their very nature have two doors for each opening, one for the elevator cab and another for the wall enclosing the shaft. For the shaft wall you can simply insert a door hosted by the shaft wall. For the elevator cab, I simply use a symbolic representation of an elevator cab created from AutoCAD lines from Otis or whomever. No need to pay for such symbols and frankly don't see the real value in having a 3D elevator cab in my model. As long as the shaft opening is the correct size what does a 3D model of an elevator cab give you? My 2 cents from an 8 year Revit user and 3 year Autodesk employee.
Tom www.reviteer.com http://twitter.com/Reviteer |
Internet etiquette rule No. 1. Please Turn off your CAPS LOCK. It makes your post difficult to read and YOU APPEAR TO BE YELLING AT US.
You may also download Elevatorarchitect. It helps you on the one hand to choose the correct elevator for your building and imports it into your Revit project, and in the settings you can easily select for each level if you want to have the door opening infront or rather at the rear or both.
The plug-in is free and can be downloaded at http://www.digipara.com/DownloadEARevit.aspx
0 Posts No Rating |
The lift on first and second floor separate entryways opening is the best plan, meanwhile, you'll, in the long run, get to someplace the way for the lift is individual locations on various floors.
need help on elevator... |
Fri, May 25, 2018 at 4:23:17 AM
New Elevator Family |
Wed, Sep 13, 2017 at 6:42:18 AM
elevator BIM model |
Fri, Sep 14, 2012 at 4:04:11 AM
Fire door in front of elevator door |
Thu, Feb 3, 2011 at 1:37:28 PM
Elevator / Maint. Pit - Revit Architecture 9 |
Mon, Mar 30, 2009 at 2:20:14 PM
Members: | 2056445 | Objects: | 23069 | Forum Posts: | 152325 | Job Listings: | 3 |
