136 Users Online (133 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Open GL & Graphics Card
Tue, May 9, 2006 at 9:09:17 AM | Open GL & Graphics Card
SteveB
3.5 Stars: 5 Votes
I have never been able to use Open GL hardware accelartion setting because my graphics card purports to support it but revit has many problems when using that setting, as a revit dialog window warns may happen when you select it... (settings->options->graphics)
My card is an NVIDIA Quadro FX 1400, I installed the latest "Autocad certified" driver.
[1] Can other users tell me what cards they have and if they are working well with OpenGL?
[2] does having OpenGL on fix the problem I have a lengthy forced refreshes when shadows are on?
[3] other benefits to OpenGL?
Thanks
Tue, May 9, 2006 at 7:17:45 PM | RE: Open GL & Graphics Card
eldados
eldados Avatar
4.5 Stars: 8 Votes
I have the same card. you can spend $$$$ on a card but you will see no benefit in Revit just yet. the problem is that the card manufactures don't get the info they need from revit in order for openGL to work! this might take a while... pissed me off for a while there Smile
Integrator
KarelCAD
lumion graphics card use
Tue, Dec 2, 2014 at 2:03:23 AM
Graphics card causing crash
Tue, May 6, 2014 at 12:31:01 PM
7600 GT GRAPHICS CARD COLOUR PROB'S IN REVIT
Wed, May 7, 2008 at 11:34:39 PM
Revit graphics card?
Thu, Feb 20, 2014 at 12:47:11 PM
Graphics Card
Mon, Aug 8, 2011 at 2:33:05 PM
Page generation time: 0.6846
