85 Users Online (81 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Parametric Area family or boundery Family
Mon, May 8, 2006 at 10:25:37 AM | Parametric Area family or boundery Family
elvis
Hi all, refering to my earlier thread, that importing data from excel is not possible! I have the following issue. the create an functional programm for a complex building a could use a parametric Area family, or boundery family, with or without 3d content, that could generate the Areas of that family and the derived family types from that. To create the entire building program I need to adjust a few parameters in that family, like Width, Height and Proportion. I tried to create a family excisting of boundery lines, but Iwas not able to lable the dimensions, I also tried to create a wall family with a closed region, but didn't work either Even the area plan boundery didn't work. After that i tried to create a generic family, with a generic annotation tag for the area but couldn't get i working? Any clue? thnxs E enclosed is a scheme that I could like to create and to adjust, the area data will be exported to excel The color fill funtions should be working aswell, for the representation.
Mon, May 8, 2006 at 10:58:34 AM | RE: Parametric Area family or boundery Family
TomDorner
4.5 Stars: 25 Votes
Through the API in version 9 I think it would be possible to take the Excel data into Revit. You would have to know how to program in .NET to make it happen. You may also want to explore using a "mass" family for the areas since in the mass family you can add the parameters you need and schedule the areas and volumes. Tom
Wed, May 10, 2006 at 7:17:56 AM | RE: Parametric Area family or boundery Family
elvis
thnxs,
i started of with a mass building block with several types , and it works fine untill now, all parameters are set,and I use the MARK parameter to have a unique name for each room.
I will ask a friend [a .net programmer] to have a look into the Excel thing, because that would be really cool].
grtz
E
Area of Generic 4 Point Adaptive Panel Family
Wed, Jan 20, 2016 at 10:31:29 AM
Editable nested family inside parametric array host family
Wed, May 19, 2021 at 8:05:22 AM
parametric Curved Family adjustable angle
Mon, Aug 12, 2024 at 5:24:08 AM
Can't area select a custom family?
Wed, Oct 9, 2013 at 2:27:34 PM
Family needs to multiply over an area
Thu, Aug 15, 2013 at 7:34:39 AM
Page generation time: 2.8656
