64 Users Online (63 Members):
Forums >> Revit Building >> Technical Support >> Openings ??
15 Posts No Rating |
Im sure I cant do this but I'll ask .... can I change the cut angle of an opening?? (e.g make it cut a 25d or 45d etc) cheers again andrew
Post edited on 2006-05-04 17:57:48
![eldados Avatar](user_avatar/6083.jpg)
![4.5 Stars: 8 Votes](/images/stars_4.5.gif) |
don't think you can, but i would use voids...
Cheers, Voids look interesting! And is possibly what I need; is this what you would use to create as slab thicking?? I’m trying to create a complex slab with thicking’s of different depths and I’m currently joining slabs above one another the create the step, but need chamfers (angles) for the transition.
Looks like I can uses one slab thickness and remove voids to suit? hmmm now just have to work out how to use them !!
Copy Monitor Shaft Openings |
Thu, Oct 21, 2010 at 8:16:14 PM
Curved wall openings |
Fri, Oct 15, 2010 at 12:42:11 AM
Openings in different phases |
Tue, Apr 20, 2021 at 7:23:42 PM
Openings--how do you control constraints? |
Thu, Jun 11, 2009 at 1:57:49 PM
face based shapes with openings |
Mon, Mar 9, 2009 at 3:10:10 PM
Members: | 2016974 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
