Forums >> Revit Building >> Technical Support >> Site Plan Linking
ok...being that my office is only 5 months into our Revit venture, we are still trying to iron out some of the kinks. we are wrapping up our 1st CD set (a 14,000 sf retail project). we decided to keep the site plan in autocad, and link it in. we are now encountering problems with it, as dimensioning it in Revit is impossible to maintain as we change the linked .dwg file. and if we want the dim's to stay when we reload the dwg file, we need to introduce reference planes/lines to dimension to. hindsight is 20/20,
so i ask this:
moving forward, i see the importance of having a site plan file in revit, and maintaining it there. is it a simple linking procedure? if the site is relatively flat, is it best to not model it, and to leave everything 2-D linework? the site plan can still be 2-D, with objects modeled within it if necessary (ramps/stairs, trash enclosures...) is this how everyone else works? are there any tips/tricks that you guys when using this method?
Thanks in advance
Site tools in Revit are in need of a major upgrade.
I only do a Revit site for rendering purposes only (seperate site project with building linked in)
For CD's, we keep the site all in AutoCAD and xref in a DWG of the Revit building from a view we setup for exporting so if we make changes to the Revit building we simply re-export the DWG to same name and location to let ACAD update the Xref.
Since we are usually using a civil consultants dwg of the site anyway, I find keeping our site plan in AutoCAD the best approach.
If I was working on a simple site plan with no civil engineers involved, I may opt to go the complete Revit route with the site.
Tom
So you just put up with the slightly different appearance of ACAD and Revit dims, fonts, etc? it isnt the end of the world i guess...where do you do your keynoting? ie. do you maintain the entire sheet and all of its keynotes, dims & other graphics in AutoCAD?
right now i am set up linking in the ACAD file into revit, so we can use the keynoting features and keep all of our sheets together in revit. What you are saying about the civil engineer is a problem we have encountered as well though. i guess i was just looking for a survey of who uses which method and in what capacity do they use that method.
Thanks
I have to say that you guys are creating more headaches than needed...
I would always create the site in revit, especially if it's a flat(ish) site, if you have a complicated site, than more the reasons to model it, that way you will have an accurate represantation of your site in relation to your building, I wrote a tutorial covering just that.
what's the point of modeling your building in 3d and keeping the site 2D?
anyway, that's what I think each to their own...
where is your tutorial posted, revit city or augi
i can't seem to find it in the revit city listings.
Post edited on 2006-05-05 12:19:05
I keep the "offcial" site plan in 2D since that work is being done by a thrid party using AutoCAD of one of the verticals for civil work. We aren't getting paid to model the site and all the utilites so I simply do a limited site plan for rendering purposes only.
If Revit ever can get us better site modelling tools I may change my theory, but in the end we still have to make money and if the site is already being done by others in AutoCAD that is where it will stay.
Tom
in revit city
ok...so i am maintaining everything in AutoCAD now, but i am still linking in the file, so i can utilize the blow-ups and cross referencing. the issue is, my fractional dimensions arent seperated with a slash, they are seperated with a # sign. as you can imagine, this is making them a little difficult to read. any suggestions on how to fix this?
-edited post- never mind we fixed it. it had to do with my AutoCAD dimensioning and i had diagonal fraction format on, they need to be "not stacked" to link correctly.
Post edited on 2006-05-08 12:18:03
i read all this post with some interest. i think i agree with eldadas, and wonder why others are making their lives so hard. we always attempt to use revit first, second and twentieth. sites are no different. but i completely understand the desire to bring in a civil or survey autocad drawing. we are newbies to some extent but all we do if we need to use another's drafting - turn off the toposurface, and link in the autocad drawing. and leave the building on. if we have things within the toposurface like subregions, then we edit the autocad drawing a bit, then bring it in. or because revit is great at creating views, make two site plans, one with our stuff, the other combing some of our stuff and the other's stuff.
Site plans and Linking with Master files |
Fri, Jul 7, 2006 at 6:55:41 PM
Linking Project in Site Plan... how to show buildings floor plan? (2010) |
Thu, Jul 22, 2010 at 1:54:35 PM
Linking buildings to a site |
Thu, Sep 16, 2010 at 4:28:49 PM
Linking the same revit model into a site with different RL's |
Wed, Sep 12, 2007 at 9:14:43 PM
site plan disappears intermittently |
Thu, Mar 16, 2017 at 9:21:13 PM
Members: | 2115407 | Objects: | 23192 | Forum Posts: | 152320 | Job Listings: | 3 |
