96 Users Online (93 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Curtain wall mullions
Wed, May 3, 2006 at 9:39:51 PM | Curtain wall mullions
puzzle
4 Stars: 10 Votes
I have put a curtain wall in a project but there are no mullions loaded into the project. I can’t figured out where to load the mullions from. Are there mullions in the metric folder? Any help would be greatly appreciated. Thanks
Macca
Sunshine Coast
QLD Australia
Wed, May 3, 2006 at 9:44:25 PM | RE: Curtain wall mullions
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Okay, this is a little confusing... Mullions are System families which always reside within the project, however these system families can also use profiles that you load in. Its sounds as though you have most likely purged out all the mullions... They are still in the project its just that all their types have been removed. You have two options: 1. Use transfer project standards from a clean template and copy curtain wall mullions OR 2. In your project browser scroll down to the families section, expand curtain wall mullions, right click each required mullion family and select new type, then set it as required. HTH.
Wed, May 3, 2006 at 9:50:12 PM | RE: Curtain wall mullions
puzzle
4 Stars: 10 Votes
Thanks for your help Mr Spot. just feel like kicking yourself when something so simply can seem so hard. Cheers PS If I still lived in Brisbane I would have definately applied for the position at your firm.
Macca
Sunshine Coast
QLD Australia
Fri, Jan 11, 2008 at 9:22:16 AM | Curtain wall mullions
erica45830
Shouldn't a corner mullion have been loaded from transfering project standards? All I got was the 2.5"x5". I tried creating a corner mullion and it won't let me check the box in the parameters box. Any help is welcome and thank you.
Curtain wall with splayed mullions
Tue, May 10, 2016 at 2:05:32 PM
Miter Curtain Wall Border Mullions
Wed, Apr 21, 2010 at 3:04:58 PM
Angled and Straight Curtain Wall Mullions
Mon, Feb 27, 2012 at 12:19:12 PM
Curtain wall and mullion issues
Wed, Sep 5, 2007 at 7:38:15 PM
CURTAIN WALL MULLIONS
Wed, Mar 29, 2006 at 3:39:14 PM
Page generation time: 1.9282
