35 Users Online (34 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Export insertion point???
Wed, May 3, 2006 at 7:41:09 PM | Export insertion point???
Andrew1
Is there any way of dictating where the insertion point is for a model or drawing when exported out of revit as a .dwg?? Currently it defaults to the center of the drawing in Revit. Cheers all Andrew Post edited on 2006-05-03 19:41:59
Wed, May 3, 2006 at 7:54:41 PM | RE: Export insertion point???
Andrew1
I have found this in the help files !!!
"Under Coordinate System Basis, select either Project internal or Shared.
If you select project internal, the origin of the exported AutoCAD or Microstation file is set to the Revit Structure project’s internal coordinates. If you select Shared, the origin (0,0,0) of the exported AutoCAD file is set to the shared location of the Revit Structure project, and all geometry is exported relative to the shared coordinates. Note that the Shared option is not available for Microstation files and only the Project internal option is available for SAT files."
but it a little fluffy (IMO) cos i dont know how to change my revit projects internal Coordanate so once exported are the same as AutoCAD (0,0,0) point or am i reading this wrong ??
Post edited on 2006-05-03 19:57:49
Wed, May 3, 2006 at 9:51:26 PM | RE: Export insertion point???
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Place a spot coordinate somewhere in your revit project and you'll soon find out exactly where your revit Origin is...
Wed, May 3, 2006 at 11:06:46 PM | RE: Export insertion point???
Andrew1
That’s a cool command but, so then how do change the origin position?? Sorry for all the Q's my reseller is not good at getting back to me we are about to complain!!! Post edited on 2006-05-03 23:12:13
Thu, May 4, 2006 at 2:31:08 AM | RE: Export insertion point???
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
you can use relocate project in the tools menu or just move all your elements as appropriate.
Revit Export Block Insertion Points
Fri, Oct 2, 2009 at 2:16:39 AM
Insertion Point of Custom Titleblocks / Title Blocks
Tue, Oct 13, 2009 at 2:57:30 PM
Insertion point - families
Thu, Dec 3, 2009 at 7:21:52 AM
Tag Leader Origins
Thu, Mar 17, 2005 at 12:45:31 AM
Export the Point cloud file to Auto CAD with Revit
Wed, Apr 2, 2014 at 4:38:32 PM
Page generation time: 0.6460
