71 Users Online (70 Members):
Forums >> Revit Building >> Technical Support >> Wall Floor Intersection Cleanup
![3.5 Stars: 5 Votes](/images/stars_3.5.gif) |
Is there a way to force a cleanup & cut the volume of a floor out of an intersecting wall. This seems to happen when you create or edit floors that overlap walls but is not available thereafter.
I have found that you can use the edit cut profile command and you can cut things out of a wall they only show up in the veiw that you put them in. Try this it might be what you are looking for. In your help menu look up Edit Cut Profile it will show you how to use this tool.
Yes, but that gets very tedious to deal with every layer. With the auto cutout function, it is all cleaned up.
Try Selecting the slab and click the edit button go into it and then tell it to finish the slab again i think that it will as you agin if you want to cut the geometry.
Maybe I'm miss understanding the issue, but when i want to cleanup a floor/wall intersection that are overlapping i use join geometry...?
That works, thanks.
You can also modify the wall type to allow stretching the outer layer of material.
edit wall -> edit struture -> preview ->modify
then zoom in to the bottom or top & hover over the bottom edge of the outer wall layer and toggle "lock" the layer you want to stretch and everything else unlock. You may have to zoom way in for this lock icon to appear. I am not sure what the logic is to which wall layers are locked or unlocked but lock the layer you want to stretch and unlock all others. lt has to match locked states at the top of the wall too (i think). Then in a section you can just stretch these up and down, like the masonry in the jpg.
Custom Wall Cleanup tool |
Mon, Jan 18, 2016 at 2:12:14 PM
Joining Cavity wall with separating wall |
Mon, Jul 14, 2014 at 9:12:31 PM
Intersection of two Barrel Vaulted Ceilings Cleanup |
Wed, Jul 29, 2009 at 12:26:51 PM
Help with floor and wall intersection |
Fri, Feb 24, 2012 at 7:49:19 AM
WALL CLEANUP |
Sat, Jan 23, 2016 at 5:16:51 AM
Members: | 2016974 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
