87 Users Online (86 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Door deletes when I edit wall type.
Mon, May 1, 2006 at 2:16:20 PM | Door deletes when I edit wall type.
rkitect
rkitect Avatar
4 Stars: 29 Votes
I have a regular ol' 36x84 single flush door in a wall type:
Finish 1[4] : Finish Gyp : 3 5/8" : wraps on
Thermal Air[3] : Air : 1 1/2" : Wraps on
Structure[1] : Steel : 9" Wraps off
and it works fine. When I went to edit the wall type to add the last two lines here:
Substrate[2] : Metal Furring : 2 1/2" : Wraps off
Finish 1[4] : FRP : 1/8" Wraps on
It all the sudden had to delete the door and will not accept anymore doors. Any clues as to what I am missing here?
Thanks for your help!
pS: tried turning the substrate wrap on and still nothing.
Mon, May 1, 2006 at 2:22:47 PM | RE: Door deletes when I edit wall type.
rkitect
rkitect Avatar
4 Stars: 29 Votes
Ok.. here's what I found out...
This does not work:
Substrate[2] : Metal Furring : 2 1/2" : Wraps on
This does work:
Substrate[2] : Metal Furring : 1" : Wraps on
Is there a limit to the thickness of a wall that can accept a door?
Thanks again.
Mon, May 1, 2006 at 2:27:03 PM | [RESOLVED]: Door deletes when I edit wall type.
rkitect
rkitect Avatar
4 Stars: 29 Votes
Apparently my door families are messed up. Reverted to an older door library and it worked fine.
Wall Thickness in Type Parameter
Fri, Jun 1, 2018 at 7:39:15 AM
Family deletes type at import
Thu, Feb 12, 2015 at 7:56:57 AM
Door tags and Door Type ID
Wed, Jul 10, 2013 at 1:40:25 PM
Same Door Type, Different Frame Type
Thu, Jul 24, 2008 at 3:16:26 PM
Host Wall type in Door schedule
Fri, May 31, 2019 at 6:07:58 AM
Page generation time: 1.2662
