51 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Tips & Tricks >> Is it possible to change the lineweight of dimension text?
Mon, May 1, 2006 at 9:27:40 AM | Is it possible to change the lineweight of dimension text?
psubenhess
I must be missing something obvious or else it's just not possbile to do it. Any help would be greatly appreciated. Thanks in advance.
Wed, May 10, 2006 at 4:53:24 PM | RE: Is it possible to change the lineweight of dimension text?
kl0an
Text command, on the options bar click on priorities, in the element properties dialog box select edit/new, in the type properties dialog box select duplicate, give the new type a name, modify as needed... I think you'll find your answer there..
Is it possible to change the lineweight of text in a dimension?
Wed, Apr 16, 2008 at 11:53:43 PM
Dimension Text [ 1 2 ]
Tue, Jul 8, 2008 at 9:15:08 AM
18
Dimension Text Overide
Wed, Jun 27, 2007 at 7:13:43 PM
cHANGE DIMENSION TEXT
Thu, Aug 2, 2018 at 1:49:45 PM
Why I cant change Dimension fonts?
Thu, Aug 10, 2017 at 11:51:40 AM
Page generation time: 1.0390
