57 Users Online (56 Members):
Forums >> Revit Building >> Technical Support >> Slabs ??
15 Posts No Rating |
I would like to make thickings to my slab but are unable to find how ??
![latemore Avatar](user_avatar/6368.jpg)
![3 Stars: 2 Votes](/images/stars_3.gif) |
are these edge thickenings? if so investigate host sweeps. otherwise you can try mr spots trick of creating extra pieces of floor and join geometry?
Thank you for your response. The thinking I hope to create are a combination of edges and some centrally in veering depths . My central ones are complicated due to no walls above and my edges are by needing a veering offsets for the edge!! So host sweep will not work … unless some one knows better?? I think the only way is to create a second slab under and join it as you have pointed out!! It just seamed a round the bush way so though I would ask in the hope
Cheers
Andrew
Floor slabs showing dashed instead of Solid |
Wed, Jun 5, 2013 at 5:53:00 PM
12
Walls cutting slabs |
Fri, Jan 23, 2009 at 1:57:20 PM
highrise towers slabs-walls joining |
Tue, Jun 1, 2004 at 6:18:09 PM
new slabs, existing slabs, and the nature of constraint(s) |
Wed, Dec 11, 2013 at 12:21:24 PM
Sloped slabs and spot elevations |
Thu, Mar 6, 2008 at 1:18:13 PM
Members: | 2022356 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
