Forums >> Community >> The Studio >> Arena seating bowls
9 Posts No Rating |
Does anyone have an ideal solution for doing a seating bowl in revit? So far all I could mess w/ that was close is using the stair tools. But the drawback is you can cut holes for the vomitories. I've been messing w/ revit for a couple of weeks now so I know that some of you more experienced users would be able to chime in if you don't mind.
Thanks
you can model it with floors, you can use the stair tool and maybe create 2 halfs... whatever easier
tell us if you get stuck
i did a mezzanine by creating a bunch of stacked floors. the Mezz follows a radius, so it is similar to a bowl. i wouldnt do it with stairs, but i always struggle with the stair modeler. so far i have had no problems with the floor components.
9 Posts No Rating |
"i did a mezzanine by creating a bunch of stacked floors. the Mezz follows a radius, so it is similar to a bowl. i wouldnt do it with stairs, but i always struggle with the stair modeler. so far i have had no problems with the floor components."
Did you create each floor run level in the same sketch session or did you have to finish the sketch then start a new one?
Thanks
i finished that sketch and started a new one. so now if i ever want to change the depth of my levels, they are all on 1 generic floor type. it should work pretty well. i dont know if this would work or not, but could you create a 50' deep slab, and do a void blend to remove the excess?
Arena Seating Bowl |
Thu, Nov 13, 2014 at 11:48:14 AM
Wall hosted arena seat |
Wed, Nov 17, 2010 at 9:27:58 PM
stadium style seating |
Thu, Apr 30, 2009 at 9:36:58 AM
auditorium seating |
Wed, Mar 7, 2007 at 8:43:03 AM
Retractable seating |
Sat, Apr 30, 2016 at 9:18:13 AM
Members: | 2114692 | Objects: | 23192 | Forum Posts: | 152319 | Job Listings: | 3 |
