76 Users Online (76 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Creating roof
Wed, Apr 26, 2006 at 11:40:42 PM | Creating roof
jyothi
Hai, I need to create a roof which is a paraboliod shape,it has got to fixed point as slopes in two different direction. Please let me know if there are any metthod of creating it. i am attaching the image and autocad file for details Thanks, Regards, jyothi
Wed, Apr 26, 2006 at 11:50:58 PM | RE: Creating roof
jyothi
hi, This is the image for the roof,
Thu, Apr 27, 2006 at 11:08:00 PM | RE: Creating roof
eldados
eldados Avatar
4.5 Stars: 8 Votes
can't see the image but you can either create 2 rooves and join, or have a look at my tutorial for complex slabs (it is creating rooves...)
Integrator
KarelCAD
Mon, May 22, 2006 at 2:31:37 PM | RE:
djlandreneau
Where is the tutorial located?
Quoting eldados - 2006-04-27 23:08:00
"can't see the image but you can either create 2 rooves and join, or have a look at my tutorial for complex slabs (it is creating rooves...)"
Mon, May 22, 2006 at 4:55:18 PM | RE: Creating roof
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
That can be created using a simple blend. If you actually want to show the structure as well rather than a plane, i'd create a mass using a blend. Then use curtain system by face on the top of the mass and turn the mass off.
Creating Realistic Texture For Roof
Tue, Feb 26, 2019 at 1:37:49 PM
Creating a roof that slopes with the walls
Sun, Feb 27, 2011 at 2:35:54 PM
creating a joined wall roof system ?
Mon, Apr 2, 2012 at 8:50:08 AM
Creating a Roof Plan in Revit
Wed, Oct 3, 2007 at 8:51:58 AM
Roof design problems
Fri, Jul 9, 2010 at 7:30:00 AM
12
Page generation time: 4.2254
