52 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> levels in sections/elevations
Wed, Apr 26, 2006 at 3:50:29 PM | levels in sections/elevations
gdoorn
1 Stars: 1 Votes
ok...so i know when you copy a level tag it does not associate with a particular view, which is perfect for what i want. i am working on wall sections, and everytime i add (or rather copy) a level line i have to go back to all the other views and hide it in that view. is there a way where, when a level is copied, it is only visible in that view, and you can "show annotation object in view" instead? i have a building with many T.O. Window levels, as well as parapet heights, and it is a pain in the neck adjusting each view for a level i only need in 1 wall section. thanks!
Wed, Apr 26, 2006 at 4:39:53 PM | RE: levels in sections/elevations
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Nope unfortunately that's not possible.... Alternative would be to draw a line in that 1 view for the head instead of creating a level for it. The only issue would be is the line would get cropped by the crop region and not extend like a level...
Tue, May 9, 2006 at 11:18:22 AM | RE: levels in sections/elevations
lushin
Also consider using a symbol version of the level. You can create a family that has a leader, elevation marker and editable text for the name and height of the level that can either be automatic or noted by the user. This is what my firm has been using and it works pretty well. You can also alter a spot-dimension family to use the elevation marker and name text, that makes a pretty good auto referenced level.
Casework Elevations and Sections
Wed, Jan 16, 2013 at 3:42:10 PM
Levels, Disappeared. [ 1 2 ]
Sun, Sep 24, 2017 at 7:44:34 AM
16
Levels
Fri, Jul 24, 2009 at 3:01:28 PM
Grids, Levels, and View Templates
Fri, Nov 1, 2013 at 4:40:54 PM
Phaseing Levels
Fri, Oct 15, 2010 at 6:23:51 AM
Page generation time: 1.2082
