79 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> appearance of curved curtain walls in plan
Tue, Apr 25, 2006 at 8:11:11 PM | appearance of curved curtain walls in plan
gdoorn
1 Stars: 1 Votes
i have a curtain wall which curves in plan. the problem is that the wall shows up straight (connecting the end points)...is this because i havent added any mullions or is it an appearance setting that i need to tweak? i have not added any mullions or curtain grid, because i dont want to spend the time because the design is going to change in the near future. *edit*...nevermind...adding the curtain grid helped. i will do the mullions later Post edited on 2006-04-25 21:19:45
Tue, Apr 25, 2006 at 10:10:09 PM | RE: appearance of curved curtain walls in plan
TomDorner
4.5 Stars: 25 Votes
As you have discovered, Revit considers "curved" curtain walls to be constructed of individual segments that are straight. This is what happens in 99.9% of real curved curtain walls. You can add the vertical spacing directly into the curtain system type so that if it changes it is easy to update. On the of chance that your glazing panels do actually need to be curved, I believe there is a family out there somewhere that does that. Tom
Curved Mullion within Curtain Walls
Mon, Oct 5, 2009 at 6:09:40 AM
curved angled curtain walling
Wed, Mar 8, 2006 at 4:18:51 AM
curved curtain system -diagonal grid system?
Wed, Feb 11, 2009 at 4:24:48 PM
curtain walls
Sun, Dec 7, 2014 at 9:29:55 PM
curved curtian walls
Mon, Nov 13, 2006 at 6:19:29 AM
Page generation time: 1.3474
