88 Users Online (87 Members):
Forums >> Revit Building >> Technical Support >> Sidelight Constraint
34 Posts No Rating |
Not sure if this is a difficult one but I cant seem to get a reply. I am unable to find a way to offset my entry door sidelights. Entry doors move ok but I cant align the sidelights.
Please help!!
Thanks in advance
Steve
![eldados Avatar](user_avatar/6083.jpg)
![4.5 Stars: 8 Votes](/images/stars_4.5.gif) |
go into your family and make sure the side lights are constrainted and locked to the bottom of your door that way it should move with the door, if you want to move them seperatly you will need to put a reference plane, put a dimension with a parameter and lock your sidelights bottom to the reference plane.
is it clear enough?
Thanks Eldados.
Sounds ok. Sidelights are separate to the door. Will try the dimension and parameter.
Regards
Steve
Ballina NSW Australia (nearly as much sun)
Door Sidelight Constraint |
Mon, Apr 24, 2006 at 12:56:28 AM
Door with on/off sidelight visibility |
Thu, May 26, 2011 at 2:38:03 PM
Door with Sidelight - Instance parameters |
Tue, Jul 27, 2010 at 4:09:31 PM
Laundry door & sidelight? |
Mon, Dec 11, 2006 at 7:34:32 PM
Keep getting constraint error in "Nested & Arrayed Families by: Mr. Spot" tutori |
Wed, Dec 8, 2004 at 3:13:13 PM
Members: | 2016974 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
