41 Users Online (40 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Failure to Copy/Monitor Correctly
Thu, Oct 20, 2016 at 12:58:19 PM | Failure to Copy/Monitor Correctly
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
I'm trying to copy/monitor a floor slab from a sub grade parking model to an above grade model. However, Revit copy/monitors the slab object incorrectly - it copies to some unknown offset value. Properties for each object in both models are identical including level data, but Revit still fails to copy/monitor correctly. Does anyone have a resolution to this error?
Thu, Oct 20, 2016 at 1:24:11 PM | Failure to Copy/Monitor Correctly
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
Looking deeper I see that the original object has modified subobjects - outside points are set to varying offsets. The copy/monitor operation apparently ignores this? Why would that be?
Thu, Oct 20, 2016 at 1:55:04 PM | Failure to Copy/Monitor Correctly
Copy monitor is a coordination tool intended to be used with a linked model and is the SAME element but in the host model.  It is not a copy process to be used in completely different models.
Thu, Oct 20, 2016 at 2:06:57 PM | Failure to Copy/Monitor Correctly
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
Thanks for your reply 'hub, but that doesn't answer my question. I'm am utilizing this process to coordinate objects between models. I understand how copy /monitor works. The question is, whether the modified sub-elements in the object that is desired to be coordinated is intentionally ignored in the copy /monitor process and if there is a solution to overcome it. Thanks.
Thu, Oct 20, 2016 at 2:13:47 PM | Failure to Copy/Monitor Correctly
Your HELP says:
Shape-edited floors: If you use Copy/Monitor to copy a shape-edited floor (or slab), the copied element is flat. Use the Slope Arrow tool to slope slabs when possible, or use a separate slab in each building model. See Sloped Surfaces.
Thu, Oct 20, 2016 at 3:38:51 PM | Failure to Copy/Monitor Correctly
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
There it is. It's just missing functionality. Got it. Thanks.
Edited on: Thu, Oct 20, 2016 at 3:40:35 PM
Copy/Monitor walls
Tue, Apr 2, 2013 at 10:14:23 AM
Copy Original Type Not Available in Copy Monitor Options Dialogue
Fri, Nov 6, 2015 at 2:16:27 PM
Can't Get Copy Monitor to Work for Grids and Levels
Fri, Feb 21, 2014 at 4:55:28 PM
Copy/Monitor Lights to Revit Architecture 2012
Wed, Oct 17, 2012 at 3:05:52 PM
Rev Arch 2009 conultants elelments in copy monitor
Wed, Aug 31, 2011 at 2:21:36 PM
Page generation time: 0.5586
