79 Users Online (78 Members):
Forums >> Revit Building >> Technical Support >> Does not print anything but annotations
I just started having this since yesterday in version 2015.
Trying to print visible poirtion of current window, fit to page and tada-
Nothing printed except annotations. See screenshopt attached for what I was trying to print on left side and what ended up printing on right side. This happens when I print to pdf AND a phisycal printer. So I'm assuming this issue is from Revit?
Does anyone else have had this issue? Any suggestions?
It may be your print driver or .... have you installed all of the updates for Revit.
It seems to do something with "visible portion of current view" since it prints fine if I choose to print the whole window. Yes I did update to the latest release and no I do not think it is the printer driver (If it happens to be printer driver, how to fix??). It is strange it happens to both pdf and physical print only when I print portion view.. I know the workaround to print the whole sheet first to pdf and then print portion view from pdf app, but it is a pain to go through an extra step..
I can say this, I have never seen this problem in 2015 nor has anyone complained about it. I think it is your system or possibly a corrupted program. I doubt if it is your file but try it from another system if possible. The fact that you just started having prob lems suggests other factors. Try using cutepdf, it's free.
Last month I posted that a recent windows update caused printing issues. Check this out more:
Everything but Annotations print off halftone HELP! |
Tue, Dec 9, 2008 at 4:18:33 PM
Can't load annotations |
Wed, Jun 27, 2007 at 4:23:05 PM
Electrical shows up in plan view, but will not print.. Help! |
Mon, Jul 21, 2014 at 3:04:35 PM
Annotations accidentally snapped into linked dwg (Imported categories) |
Tue, Jul 9, 2013 at 5:53:11 AM
Beam Annotations |
Fri, Sep 2, 2011 at 4:32:37 PM
Members: | 2056220 | Objects: | 23069 | Forum Posts: | 152281 | Job Listings: | 3 |
