39 Users Online (38 Members):
Forums >> Community >> The Studio >> plotting revit sheet with kip plotters
1 Posts No Rating |
Does anybody already use a Kip plotter to plot out Revit sheets? And if so, is there a special driver from Kip that I need from them (such as a windows driver, like a laser printer??)
8 Posts No Rating |
I use KIP and for the first time yesterday I got it to work properly. I had to print them all as .prn then go to the folder and change them all to .plt It actually worked! they came out the right size and lineweights and everything!
4 Posts No Rating |
Greetings - I too am using a KIP 6000, and having problems with time delays on the "Print Window" loading (takes over a minute per sheet) and the actual print processing once I click "OK" (takes about 5 minutes to actually plot 1 sheet) I have tried Ploting DWF instead of PRN with 95% good results, however some of my Revit title block and Level text shifts - going from Kip Request to the 6000 Plotter. I am now trying about every driver that Autudesk, my Kip support tech and my Revit tech support are giving me. Anyone else have an iedas? Thanks, James
Kip Plotters - Printing Issues |
Tue, Mar 4, 2008 at 10:15:07 AM
Batch Plotting |
Thu, Mar 19, 2009 at 8:46:20 AM
Setting a project up to easily plot between different sheet sizes/plotters |
Sun, Jul 18, 2021 at 10:22:33 AM
Problems plotting Revit 9.1 to HP755! Help! |
Wed, Jan 31, 2007 at 7:47:22 AM
Problems plotting |
Mon, Nov 9, 2009 at 3:38:20 PM
Members: | 2017275 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
