29 Users Online (28 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Labeling Dimensions
Mon, Apr 24, 2006 at 11:04:01 AM | Labeling Dimensions
patpatt
I am a newbie at Revit and am wondering if you can label dimensions in a project? I want to be able to control the placement of items by using formulas to control their space i.e. space between walls if building size changes the room size can grow being a percentage of length.
Mon, Apr 24, 2006 at 11:32:04 AM | RE: Labeling Dimensions
TomDorner
4.5 Stars: 25 Votes
As far as I'm aware, you can't place a label on a normal Revit project dimension like you can in the familiy editor. You can however use dimensions and reference planes to accomplish what you are after. If something is to remain eqadistant between two things, dimension the object, hit the blue "eq" symbol on the dimension and it will report and lock to eq/eq. You can remove the dimension, and Revit will ask you if you want to remove or keep the equality constraint your choice. If something is supposed to be 1/3 of a length away from something else, add 2 reference planes, dimension them to eq/eq/eq, remove the dimension but keep the constraint, insert object and align and lock it to proper reference plane. HTH Tom
Mon, Apr 24, 2006 at 1:24:50 PM | RE: Labeling Dimensions
patpatt
Okay I have to be missing something. I cannot dimension reference planes using EQ dimensions. The only thing I seem to be able to do this with in projects is walls. I am using Ver. 8.0 if that matters.
Mon, Apr 24, 2006 at 1:49:50 PM | RE: Labeling Dimensions
TomDorner
4.5 Stars: 25 Votes
I no longer have 8 installed, but works in 8.1 and for as long as I have been using Revit since 5.0 I believe reference planes can be dimensioned. It works fine in 8.1. Tom
labeling dimensions
Mon, Feb 15, 2010 at 12:59:10 PM
Labeling this dimension would overconstrain the sketch. ??
Sun, May 3, 2009 at 11:14:09 PM
Wall Type Tag Labeling Convention
Thu, Sep 25, 2008 at 9:24:51 AM
Family Help Please! 'Labeling this dimension would overconstrain the sketch.'
Wed, Jun 10, 2015 at 9:18:40 AM
EQ Display in dimensions Revit 2009
Tue, Mar 23, 2010 at 3:28:36 PM
Page generation time: 1.1828
