62 Users Online (59 Members):
Forums >> Revit Building >> Technical Support >> contours
18 Posts No Rating |
Hi,please let me known how to do contours in easy method ,I have acad dwg only with elevations in meters and lines are in spline how can I take it to Revit and do the contouring.It is very very urgent.
Thank u.
52 Posts No Rating |
hai Bhawani,
How are u?
is ur contour plan in Autocad is in 3-D or only 2-D.?
if its only in 2-D give each point the elevation and convert to 3-D in autocad, then import to Revit and go to site-- select topography---use imoprted-- select the layers which as got elevation it will automaticall create site for u. i am also creating a huge site using this method and it worked fimne.
The other method is after importing Autocad dwg to revit u can give elevation to each point and say finish sketch.
Bye
let me know if it helped
Smoothing contours... |
Tue, Feb 17, 2009 at 8:43:14 AM
New vs. Existing Contours [ 1 2 ] |
Thu, Jun 28, 2012 at 2:27:20 PM
16
Topo surface Control from imported contours |
Mon, Feb 17, 2014 at 7:28:49 AM
Changing the amount of contours between intervals. |
Tue, Sep 20, 2011 at 3:00:40 PM
printing contours |
Fri, Jul 30, 2010 at 2:19:00 PM
Members: | 2022368 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
