61 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> changing scale
Sat, Apr 22, 2006 at 12:25:36 AM | changing scale
jyothi
hi all, i have a problem with the scaling in revit. I have done a site plan by importing the Autocad surey plan, after completing the site plan i relalised that the survey plan was in 1: 10 scale. i had assumed that it was in 1:1 scale as in autocad it was measuring the distance as it was dimensioned. Now imy problem is i have already completed the whole site, with split surfaces, sub regions etc, how do i scale the site model to 1: 1. what can i do the best to tackle this situation its a very big site and has taken lots of effort in building the model.Please help me regarding this. Best regards, Jyothi
Sat, Apr 22, 2006 at 2:53:58 AM | RE: changing scale
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Nasty... I don't think you have much option for the topography/subregions other than recreating them at the correct scale. I don't believe the scale tool will work on the topography. I'd imagine it will work on the sub-region sketches though...
Sat, Apr 22, 2006 at 3:49:28 AM | RE: changing scale
jyothi
hi, yes Mr spot, i tried all the possible ways but it will not work other than recreating it again. Autocad scale in sheet the drawing was mentioned 1:1, it measured also same, but i really dont understand why it was different in Revit. something wrong in dimension settings i think. Thanks for ur time Best regards, Jyothi
Sat, Apr 22, 2006 at 9:34:38 AM | RE: changing scale
itsRohit
can you post the revit file ?
Wed, Apr 22, 2009 at 4:41:14 AM | changing scale
Mufu
hi guys i have the same problem my site plan from autocad had been scaled down so now the whole building in comparison to the site is very big so plz let me knwo how u scale urs down, and i am also stuck have to rescale the whole project how can i do it plz do let me know..and mine is quite urgent
 muf
Wed, Apr 22, 2009 at 7:01:31 AM | changing scale
Re-import at the right scale ???
changing scale in sections for revit 2013
Mon, Oct 5, 2020 at 6:48:55 AM
Changing the scale of a Bump image for rendering
Mon, Sep 26, 2016 at 1:03:41 PM
changing scale
Mon, Feb 14, 2011 at 6:58:19 AM
changing the scale of my room and area tags with the scale of my area plan.
Fri, Oct 22, 2010 at 10:38:38 AM
hatch scale?
Sun, May 10, 2009 at 3:33:47 PM
Page generation time: 0.7411
