91 Users Online (90 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Walls wraping
Thu, Apr 20, 2006 at 10:19:54 PM | Walls wraping
JAIMERIOSJR
Hello everybody, I am working an addition and modifications to an existing residence. I am having a hard time with wall wrapings. 1. I need to find out how I can get the existing walls to wrap at the corners without showing either wall thickness on the view perpendicular to the wall. 2. What do I have to do in order to eliminate new walls or remove walls to go to center of the wall they are either crossing or meeting? a prompt response will be greatly appreciated
Fri, Apr 21, 2006 at 6:22:58 AM | RE: Walls wraping
eldados
eldados Avatar
4.5 Stars: 8 Votes
hello, 1. not infront of revit right now... you need to set it up in the wall properties, you can set what's showing in coarse, medium or fine, sorry i can't be more specific. 2, in the wall edit/new properties, under structure, you can set you layers as core, finish etc... each has a number 1-5 that's determines the hierarchy of that layer, have a play there Smile have fun
Integrator
KarelCAD
Wraping Stacked Walls at Curtain Walls
Wed, Dec 24, 2008 at 1:40:27 PM
Wraping wall at end
Tue, Dec 9, 2014 at 12:48:23 PM
Wraping Refering Sheet No. in Tags
Wed, Oct 13, 2010 at 8:14:09 AM
Wall wraping in windows and structural columns
Mon, Feb 2, 2015 at 11:58:45 PM
wrap exterior face of wall at ends as an instance not a type parameter
Thu, Mar 27, 2008 at 7:39:31 AM
Page generation time: 2.2777
