77 Users Online (76 Members):
Forums >> Revit Building >> Technical Support >> contours in section
3 Posts No Rating |
I have an elevation view of building with contours. The contour in section show an earth pattern that take up most of the bottom half of my building.
I tried going to properties and looking for a hide hatch pattern icon but to no avail.
Does anyone know how to hide of get rid of this earth pattern.
![eldados Avatar](user_avatar/6083.jpg)
![4.5 Stars: 8 Votes](/images/stars_4.5.gif) |
you can either go to your visibility/graphic properties and turn off topography.
or... create your pad and cut your topography, so it will show properly in your sections.
many tutorial on this around...
3 Posts No Rating |
I appreciate you advise. However I did both items you suggested previously. The heart of the matter
is that in the actually elevation view, the contours are cut in section so in result there is whole earth pattern beneath that I have tried to remove or hide. I have gone in to properties and tried to hide or remove that pattern but couldn't. removing Topography in the properties menu gets rid of my contours which is not what I want to do..
Thanks for the reply if you find any other Ideas let me know. I appreciate it.
Smoothing contours... |
Tue, Feb 17, 2009 at 8:43:14 AM
contours |
Mon, Apr 24, 2006 at 5:16:04 AM
New vs. Existing Contours [ 1 2 ] |
Thu, Jun 28, 2012 at 2:27:20 PM
16
Topo surface Control from imported contours |
Mon, Feb 17, 2014 at 7:28:49 AM
Changing the amount of contours between intervals. |
Tue, Sep 20, 2011 at 3:00:40 PM
Members: | 2017278 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
