132 Users Online (131 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> revit crash
Thu, Apr 20, 2006 at 8:33:20 AM | revit crash
masonp
3 Stars: 1 Votes
I am working a small residential project and recently encountered a problem opening the file. Apparently the file is corrupt because I either get an error message stating "failed to open document" or "an unrecoverable error has occurred. The program will now be terminated. All of your data has been recently saved, so there is no need to create recovery files." All of the backups reveal the same message. Anyone have a solution? Thanks. Mason
Thu, Apr 20, 2006 at 7:49:51 PM | RE: revit crash
Thread Post Kudo! #2
eldados
eldados Avatar
4.5 Stars: 8 Votes
try auditing before you open the file, if that failes, go back to an earlier save... but the audit should fix it. if you have a corrupt database you can send the file to Autodesk and they can fix it...
Integrator
KarelCAD
Sun, Dec 17, 2006 at 8:11:36 PM | revit crash
crazyjadles
I have someone with the same continuous error. He says it happens every hour or so. No reason at all.
Here is a screenshot of the error... we've tried 'auditing' as above but still receive the error.
CrazyJadles
aka
Jade-Elise Sadler
Mon, Dec 18, 2006 at 8:27:29 PM | revit crash
crazyjadles
Just to update on the situation this was a solution i was given. I will let you know if this fixed the problem or not.
"This is most likely caused by the graphics hardware on the system, and or the drivers.
Revit is sensitive to hardware and driver quality and works best with workstation class hardware.  More information on your current setup would be needed to determine whether this is an issue, but at the very least obtain the latest driver software for your graphics hardware.
Also, heat build up inside the machine can cause unpredictable errors such as this one, also due to the graphics system struggling under load.  Make sure the machine is clean internally as dust builds up quickly and all fans are operational.  Heatsinks and cooling mechanisms should also be cleaned so they operate efficiently.  You should engage the services of a competent computer technician to check and clean these components, plus install all the latest drivers for your installed hardware."
CrazyJadles
aka
Jade-Elise Sadler
Tue, Dec 23, 2008 at 11:53:32 AM | eldados
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Quoting eldados from 2006-04-20 19:49:50
Ho"try auditing before you open the file, if that failes, go back to an earlier save... but the audit should fix it. if you have a corrupt database you can send the file to Autodesk and they can fix it... "
How do we send to Revit?  I am getting an error every time I use the grid tool.  I can't use it without  crashing.  I detcahed from central and audited, still no go.  I am trying to figure out how to recover my back up files from the folder that is automatically created when a central file is created.
Any ideas how to do this?
Denver, CO
Revit Architecture
Wed, Dec 24, 2008 at 8:57:25 AM | masonp
unforgivable
Quoting masonp from 2006-04-20 08:33:19
"I am working a small residential project and recently encountered a problem opening the file. Apparently the file is corrupt because I either get an error message stating "failed to open document" or "an unrecoverable error has occurred. The program will now be terminated. All of your data has been recently saved, so there is no need to create recovery files." All of the backups reveal the same message. Anyone have a solution? Thanks. Mason"
Hi masonp,
I've have the same problem and I've reinstall Revit.
Try doing the same may be it'll help.
http://tutorials-revit.blogspot.com/
Thu, Jun 20, 2019 at 8:42:54 AM | eldados
josejesuslp
Thank you, man.I was striggling with a model made in parts with another softares, and this helped me out.
Crash!!!!
Thu, May 5, 2011 at 4:09:11 PM
Revit crash when dimensioning
Thu, Jul 15, 2010 at 7:38:37 AM
11
Revit Link causes crash
Wed, Dec 29, 2010 at 10:33:39 AM
Crash for single user on workshare projects
Thu, Jun 26, 2014 at 2:56:51 PM
Parametric Cabinets causing crash in RAC 2010
Tue, Aug 11, 2009 at 1:21:19 PM
Page generation time: 2.2823
