Forums >> Revit Building >> Technical Support >> Is it possible:3d section?
3 Posts No Rating |
Hi,
I need to have a 3D sectioned perspective view. I mean that I want to trim my building (for viewing & rendering purposes), so that I can see what is inside.
If not possible, is there a procedure to simulat4e this procedure?
thanks in advance ;
ac7
Go to the view, view properties and tick scope box, then adjust the scope box to cut the section you wish to show...
3 Posts No Rating |
"Go to the view, view properties and tick scope box, then adjust the scope box to cut the section you wish to show..."
hmm... I dunno for sure but I can't do what I need like that... I only have the scope box drop down selection box in sections, for example... I wanted to have that but in a 3D view (or camera view)..
Post edited on 2005-06-13 03:42:18
You can in a non-perspective 3d view (isometric)... The only way i can think you could possibly do a cut away perspective view would be to duplicate the file and enable worksets then put all the elements you wish to hide in a workset and turn them off in that view...
8 Posts No Rating |
I am new with Revit, however, I made a perspective with the camera command from the outside front of the building, then I use blind command to hide the front wall, door and windows. the result was similar to what you want. I hope this is what you wanted to do.
4 Posts No Rating |
u can draw section first, then go to 3d model, click view menu , choose orient-to other view- select the section name which you want to show in 3d.
this link at AUGI might help
http://forums.augi.com/showthread.php?t=11672&referrerid=75765
If the link doesn't work, try to search for "How To: Quick 3D Details!" in Revit forum at AUGI forum
----------------------------------- Life is never easy but nor it should be complex. Just stay simple  |
Section box in Section?? |
Sat, Dec 10, 2011 at 10:23:01 PM
13
Section tag missing on plan but section still exists |
Tue, Nov 22, 2016 at 2:58:15 PM
Section Head with Typical |
Tue, Jan 29, 2019 at 8:18:27 PM
Using 2d group for Wall section, section details called out from wall section? |
Fri, Oct 9, 2015 at 10:50:56 AM
The option to create Wall section not showing up, only building section. |
Wed, Jan 23, 2013 at 3:16:46 PM
Members: | 2115679 | Objects: | 23192 | Forum Posts: | 152301 | Job Listings: | 3 |
