28 Users Online (27 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> driveways and sidewalks
Wed, Apr 19, 2006 at 6:16:16 PM | driveways and sidewalks
bryan324
how do you create driveways and sidewalks in revit?
Wed, Apr 19, 2006 at 6:41:34 PM | RE: driveways and sidewalks
gerryh06
3 Stars: 1 Votes
Im fairly new to revit but I know of two ways. One you can create a pad. Or you can create a subregion(s) in the topography, and change the material to either asphalt or concrete.
Wed, Apr 19, 2006 at 9:50:00 PM | RE: driveways and sidewalks
ArchWestCY
4.5 Stars: 7 Votes
gerryh06 has got it. First you will need to create a topograpghic surface. There is a button for this under Site in the Design Bar. Then use the Pad button (also on the Site tab). It is easiest to plan out all of your Drives and Lots first, and do them all together. Then do your Sidewalks separately. I'll have to try the subregion technique. archwestcy
Wed, Apr 19, 2006 at 10:22:00 PM | RE: driveways and sidewalks
gerryh06
3 Stars: 1 Votes
I don't use the pad as much as I use to. It has its advantages and disadavantages. If you use the subregion technique everything will be in place with the topography. (i.e, your driveway slopes down toward your house, but you have alot of dif. contours, and may need to put a few turns here and there...) Pads the easiest and probably the best b/c you can add a thickness to the driveway/sidewalk.
Thu, Apr 20, 2006 at 6:55:19 AM | RE: driveways and sidewalks
bryan324
Thanks for the help guys!!
Thu, Mar 20, 2008 at 2:45:37 PM | driveways and sidewalks
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
I'm a relatively new user. I have been using "wall" to create curbs, this is ok in a straight line but when you try to create a curved curb it all falls apart. Sidewalks that are rectangular can be adjusted fairly easily although it could be enhanced alot by adding global elevation. What really would be great is a 3D path.
Driveways
Tue, Dec 27, 2011 at 4:57:33 AM
Extruded Curbs, sidewalks on grading
Tue, Jul 4, 2006 at 2:15:41 PM
CURBS AND SIDEWALKS!
Fri, Feb 11, 2011 at 11:58:44 AM
driveways on inclines
Mon, May 12, 2008 at 8:10:12 PM
Sidewalks that curve no change in grade
Sat, Mar 22, 2008 at 12:15:19 AM
Page generation time: 15.9220
