75 Users Online (74 Members):
Forums >> Revit Building >> Technical Support >> Crashing While Converting to a PDF
24 Posts No Rating |
While trying to convert a sections sheet into a PDF, it hits 60% and freezes. It even crashed the whole program a couple of times. We tried it on 3 different computers in 8.1 but still get the same result. We turned off all planting in the visibility/graphics, and tried it with several different fill patterns to try and simplify the drawing, but still nothing is working. Does anyone have any good ideas on what is going on.
![4.5 Stars: 25 Votes](/images/stars_4.5.gif) |
What PDF writer are you using?
I have Acrobat 6.0 Professional, but I find that PDF995 does a better faster more complete job.
You may want to experiment with it. www.pdf995.com
Tom
We run 6.0 as well. Ill give it a try, thanks for the help
![2 Stars: 3 Votes](/images/stars_2.gif) |
Another program I use with no dramas is "cutePDF". (It's also free!)
I just had this problem and mine turned out to be too many detail items on the sheet. My boss wanted a quick roof framing plan sketched out to give to the structural engineer. I used filled regions for the column locations and detail lines for the joist locations. When going to print, it would freeze up and crash. When I did finally get a pdf, it was 10,000 KB in size. I then replaced the regions and lines with model elements and it printed just fine and the pdf file size dropped to 221 KB. Valuable lesson - use model elements over detail items no matter what. Hope this helps someone else.
Print to PDF crashing |
Tue, Apr 6, 2010 at 3:55:55 PM
converting files |
Wed, Aug 24, 2016 at 9:55:18 AM
converting a revit file into PDF |
Fri, Apr 7, 2006 at 2:18:16 PM
Ceiling Tags Crashing Program |
Sat, Dec 15, 2007 at 3:03:16 PM
revit crashing |
Mon, Jan 23, 2006 at 2:28:30 PM
Members: | 2016908 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
