64 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> disappearing grid lines
Wed, Apr 19, 2006 at 3:32:56 PM | disappearing grid lines
gdoorn
1 Stars: 1 Votes
HELP!!! i am sitting 2 days away from a building department submittal, and a bunch of my grid lines in plan disappeared. i cant create new ones, because they are still visible in section/elevation. but in all of the plan views, the vertical grid lines disappeared. everything is visible in my model, and they i never "hid annotation in view" of course i lost all of my dimensions tied to these grid lines, but they still are in my elevations and sections. they are all 3-Dimensional grid lines, so that isnt it. and i have half of them visible in plan, so it isnt a visibility thing. i cant copy/paste aligned because i cant select the "paste in selected view" option. has anyone ever run into this? Please help Obi Wan Kanobe, you are our only help!
Wed, Apr 19, 2006 at 4:28:44 PM | RE: disappearing grid lines
gdoorn
1 Stars: 1 Votes
any help? sorry i dont want the thread to get buried.
Wed, Apr 19, 2006 at 5:34:47 PM | RE: disappearing grid lines
gdoorn
1 Stars: 1 Votes
ok...we got it straightened around. apparently my coworker decided to make our grid lines 3D and bring the underside of the grid extension lines above the cut plane for all of our levels. things are being returned to normal as i type. albeit i'm frusterated as hell. if the line is 2D you can adjust the grid lines vertically and it wont affect the rest of the model, but if you move them left/right, the gridlines and all associated info will move as well. i think the same goes for levels, you can move them left/right just fine if they are 2D, but if you move them vertically it will impact your model. Post edited on 2006-04-19 18:17:19
Wed, Apr 19, 2006 at 5:44:48 PM | RE: disappearing grid lines
eldados
eldados Avatar
4.5 Stars: 8 Votes
what happens when you over where the grid suppose to be? is anything hilighted? have you tried to create a scope box? not sure, never happened with grids before, I had the same problem with levels and wonder if the answer is the same... just create a scope box, boxing your model, make sure it is higher in elevation as well. click on a grid, right click and select all instances, go to properties and select the scope box you have created. let me know how you went
Integrator
KarelCAD
Break Grid lines
Sun, Jul 18, 2010 at 9:36:15 AM
grid lines extend beyond detail
Mon, Jul 20, 2009 at 2:06:00 PM
Grid Partial Visibility
Wed, Aug 3, 2016 at 1:08:39 PM
Grid Lines - Instance based text in grid line family
Mon, Jul 23, 2018 at 2:17:14 PM
Grid Lines & editable dimensions
Mon, Mar 30, 2009 at 6:11:38 PM
Page generation time: 1.1621
