45 Users Online (44 Members):
Forums >> Revit Building >> Technical Support >> Doors in Curtain walls
How can you create a door in a curtain wall?
Two methods:
1. Load a "curtain door" into your project. Then select the curtain panel that you want to be the door and change the panel to a curtain door in the drop-down box.
2. Change the curtain panel to a regular Revit style wall, then simply insert a regular Revit door. You will have to play with curtain panel widths to make sure you completely cut the "wall" with the "door".
HTH
Tom
Thanks Tom, after posting the notice I mange No. one but the second point is much better since it allows me to flip the door as well.
Thanks again.
Gar
No curtain wall doors on curtain walls! |
Sun, Nov 22, 2009 at 7:10:58 PM
Curtain wall doors |
Mon, May 4, 2009 at 2:05:34 AM
Curtain walls vs doors & windows |
Sat, Oct 15, 2016 at 4:16:00 AM
Panel tags for glass doors with frame in curtain walls |
Thu, May 1, 2014 at 7:51:48 AM
Creating Doors for Curtain Walls |
Thu, Jun 17, 2010 at 7:13:12 AM
Members: | 2022356 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
